1941 Model A
dzc3
02-12-2013 12:49:59
The serial # on my 1941 A is 506021 is a delco starter part # 1108914 the correct starter?
A GURU
02-12-2013 18:02:47
 Re: 1941 Model A in reply to dzc3, 02-12-2013 12:49:59
Yes. The 1108914 is the correct starter for SN 502232-583999.
A GURU
02-12-2013 18:35:14
 Re: 1941 Model A in reply to A GURU, 02-12-2013 18:02:47
As an added note just for my own enjoyment. I would estimate that your tractor was built about 2/20/41. This could however be off by a fair amount because the 1941 model year is one of them that has a lot of discrepancy between the beginning serial number lists and the production log numbers. The list on here has it at 2971 more tags than tractors built (possible but not likely). T-C Club's list has it at 918 more tractors than tags issued (not possible). If you should ever happen to have the serial number researched, I would be interested to know how close this guess was, if you don't mind sharing.
Thanks and enjoy your tractor.
