FactoryFarmer
I'll be the first to admit that I am not good with carbs On my 37 A it has a problem getting gas into the cylinders. It's a "rebuilt" carb from my normal guy who always does good work. The only time I could get it to run good is when it sucked a shop towel down the intake partially plugging it and creating a stronger "choke." Even on full throttle and full choke you cannot get gas to come out of the petcocks. I've had tractors before that will flood badly under those settings.
Would a misadjusted float cause this or is it something with airflow?
Thanks
Thanks
