I recently bought two John Deere B tractors one is a 1952 and the other being a 1948.
When I got the 1948 home I drained the oil and water came out with it. I then drained what was left of the antifreeze. I let it all drain out and filled it back up with diesel. I let it soak for 3 days before draining it and putting fresh oil in it.
I then drained the trans and rear end oil. Once again oil and water came out. I filled it back up with diesel and it has been soaking for 2 weeks.
I hooked up a battery to it and wanted to see if it would turn over. When I push the starter it makes a humming sound but wont pop. I then opened the cocks and with the transmission in neutral it will turn over and pop when rolling it back and forth by hand. (When I hit the starter it still just buzzed.)
When I put it in gear it will not budge with the starter or by hand. Even jerking it the pulley will not turn. I am not sure what to do next so thought I would ask for your help.
I read somewhere that if the starter is stuck this might be what would happen. Does anyone have any ideas?
Thanks in advance.
Jacob Mattson
Thanks in advance.
Jacob Mattson
