johndear720
When I got it the main clutch didn"t work and if the hi-lo was shifted to low engine almost choked down and hydraulics squalled. After unload from trailer and stomping brakes with clutch mashed main clutch broke free. However, just moving it around lots of times clutch wouldn"t release or tractor would creep if hi-lo n Hi. Shift to Lo and clutch worked fine. I bought a 2640 that appears to have had a tough life.
Put in new load control shaft, bushing, seals, cleaned trans screen, new hyd filter, and new oil. All seemed well but while idleing in shop hyd pump loaded something terrible and engine choked down. It restarted fine but when I backed it out of the shop the clutch wouldn"t release and if the Hi-Lo was shifted to low hydraulics screamed and engine loaded however clutch would release. Shift it back to Hi and everything quiet but clutch wouldn"t work. After a few minutes of running hi-lo went back to working and clutch working. Anytime the hi-lo isn"t working the clutch doesn"t seem to work correct either. Tractor has hydraulic PTO clutch and it seems to function fine. 3 point does rattle on way up. Pump drive bushings on crank pulley are worn out or gone. Haven"t gotten that far yet to replace the drive. No leaks and everything else works fine.
Hydraulic oil had water in it, good bit of metal shavings and pump screen was about 75% clogged with slimey algea looking stuff. System primes almost instantly but pump rattles a lot thanks to coupling.
Any pointers would be appreciated or at least a clue as to why the clutch doesn"t work when hi-lo acting up. Figure there is trash scattered throughout system as nasty as oil was.
