I just bought a used 2155 and the Tachometer and Hour meter are not working. I've searchd the parts catalog, and traced alot of wires. However I have not found a clear answer.
I've found 2 wire connectors (one is Brown, the other is Yellow-Black) near the Alternater that are just hanging.
There is a spot to plug 1 wire connector onto the alternator. This alternators website seems to indicate the Tachometer is run off of the alterntor (http://heavyduty.boschautoparts.com/SiteCollectionDocuments/2212161_UnivAltCat06.pdf)
Before I plug something in that I'm supposed to, do any of the other 2155 owners know if this is supposed to run the tachometer?
If yes, which wire should be plugged in?
Thanks
Thanks
