JD 2750 steel hyd. lines broke ???????
4020guru
07-27-2012 19:51:24
This is a 2750 euro model. I have two steel hydraulic lines that broke . One goes from the hyd oil cooler back to the rear , and the other line goes from the hydro pump back to the rear. One line that enters the rear does not have a bushing to threat into like the other . This connection looked wierd. The line enters the rear with no sign of threads or connection . Soo my two questions are as follows; how to I go about finding these lines?? Can I install rubber lines instead??? and how does that hydraulic line with no sine of threading attach to the rear ??? If I could get any input , I will be on happy guy because I have never delt with steel lines .
Tx Jim
07-29-2012 11:29:37
 Re: JD 2750 steel hyd. lines broke ??????? in reply to WeirdDeere, 07-27-2012 19:51:24
JDparts.com available online for FREE. It also helps that I worked for a JD dealer for several yrs and I'm fairly acquainted with JD parts system
This post was edited by Tx Jim at 11:32:18 07/29/12.
4020guru
07-29-2012 10:20:01
 Re: JD 2750 steel hyd. lines broke ??????? in reply to 4020guru, 07-27-2012 19:51:24
TX JIM where do you find these parts catalog information at ? Do you own them or have you found them online ?
Tx Jim
07-29-2012 04:23:34
 Re: JD 2750 steel hyd. lines broke ??????? in reply to Lee A. Schexnaider, 07-27-2012 19:51:24
The lines have a plug made onto them that sticks into housing with o-rings and are held in with a metal tab.
parts key #1 L34995 O-RING
parts key #14 R495R O-RING
4020guru
07-28-2012 19:54:19
Ok took them out today and found that they pulled out of the rear . They are definetly line 4 and 17 . What kind of a connection is that where the lines are pushed in , and have an o-ring ????? Yes, this is a novice question .
Tech 7
07-28-2012 16:12:16
retainer number 16 or 21 sorry
Tech 7
07-28-2012 16:10:12
Don't fool with it, buy the proper lines as shown in the parts catalog with the new packings from your JD dealer. Those lines should be held in place with an arrow head shaped retainer and a 3/8 capscrew and lockwasher.
Tx Jim
07-28-2012 12:06:04
 Re: JD 2750 steel hyd. lines broke ??????? in reply to The Dukester, 07-27-2012 19:51:24
If you're referring to the hyd line I've seen them repaired with brass,baling wire or an old fashioned metal clothes hanger.
Tx Jim
07-28-2012 10:17:05
 Re: JD 2750 steel hyd. lines broke ??????? in reply to rocky1982, 07-27-2012 19:51:24
I think a hose will not be a good replacement for line #17. Yes if line is disconnect and free of oil it can be brazed.
4020guru
07-28-2012 10:58:47
 Re: JD 2750 steel hyd. lines broke ??????? in reply to Tx Jim, 07-28-2012 10:17:05
What would be the best filler material ?
Tx Jim
07-28-2012 03:51:50
 Re: JD 2750 steel hyd. lines broke ??????? in reply to mjbrown, 07-27-2012 19:51:24
I only found 1 parts catalog for a 2750 and it doesn't state European[PC #4188 - 2750 Tractor (North American Edition) - 16Jul10]. Which of these lines are you referring to?? third party image
4020guru
07-28-2012 06:48:06
 Re: JD 2750 steel hyd. lines broke ??????? in reply to Tx Jim, 07-28-2012 03:51:50
It looks like line 4 and 17. 17 looked kind of wierd where it enters the rear. Could I use hydrualic hoses instead ? One line has a very small hole , can it be brazed ? If so , what filler would be used?
thurlow
07-28-2012 18:01:09
 Re: JD 2750 steel hyd. lines broke ??????? in reply to 4020guru, 07-28-2012 06:48:06
Filler???? All you need is a torch, bronze/brass rod, flux and a little skill.
