John Deere G Grill
1952Gtri
06-26-2012 15:05:53
Where can I find a set of good used grill sheet metal panels for a 1952 JD G. Also can the grill panels on an A fit a G they look similar in size just can't tell completely. Thanks fellas
The Dukester
06-27-2012 17:53:24
 Re: John Deere G Grill in reply to 1952Gtri, 06-26-2012 15:05:53
There's a considerable difference between an A's grill and a G's grill, the G is much wider at the front and the bolster and grill halves are wider...a lot wider.
CLW
06-27-2012 17:41:07
 Re: John Deere G Grill in reply to scottnj1, 06-26-2012 15:05:53
The G grills are larger than the A.
Resting Relics 1
06-27-2012 05:52:39
Hey 1952, You can get new reproduction grills and often they are on e-bay both new and used.You can also find them in Green magazine as well as the 2-cylinder magazine. I don't think, if I remember correctly that the A and G are the same. The G, I believe is bigger. Good Luck, John
1952gtri
06-27-2012 15:42:01
 Re: John Deere G Grill in reply to Resting Relics 1, 06-27-2012 05:52:39
Thanks John I appreciate the info.
