unstyled A serial no.
Bmaniac is right. Ahead of the flywheel. As to that other place, when I die and go there, I'll check it out and let you know where the plates are on the A's down there. Jim
ben,
The number is stamped on an aluminum plate by the flywheel and could very easily be missing. Look for a couple of 1/8" +- holes or sheared off rivets about three inches apart. Good luck. VH
