I have a slow drip coming from near the injection pump. One drop every 10 sec or so while running. Is it likely on this model that I have a start of a cracked line, perhaps it there an o-ring going out or is there no o-ring and a hard connection? The drip is coming off the lowest line near the pump connection but line above looks like it may be damp. Lots of grime there that I have to go clean off to diagnose exactly where it may be coming from. Just wanting to get an idea prior to starting to check it out.
This tractor likes to poke fun at me. Every time I think I have the last problem fixed another one shows up. Go Figure... :roll:
Also, I need to change the lube filter. Looks like I have to disconnect the hoses and hard line coming from the ported cover prior to getting the cover off. How much hyd. fluid will I lose?
John
John
