tlock0331
05-13-2012 08:51:48
Re: 60 Temperature Readings in reply to Fred from MO, 05-10-2012 07:43:50
Fred,
I have been following your posts about your 60, and it looks real nice, lot nicer than mine haha
If this helps - my 60, all original, will pull a 5' brush hog in overgrown pasture in 3rd and wont hardly get to 160, gauge wise, but what i experienced in my 720G, that i had to put a radiator in that came from my parts 70's was this....the fins were straight and clear, so i pressure washed it and sorted flushed it in the shop and water would flow out as fast as it was going in so i figured it was fine and the water coming out didnt look real bad, but when i hooked my chisel on pulling in 3rd gear i could go 30-45 minutes and the temp gauge would just climb. I could put my hand on one side of the radiator bare handed and couldnt touch the other side. So i tried flushing again, same result. So I pulled the radiator and tore off the tanks, and in the upper tank is where i found 2 hand fulls of rust/scale that was more of a real fine grit like a sand consistency and when wet just clumped and it wouldnt flow through the tubes, nor would it come out of the top of the tank when i had turned it upside down and flushed prior to putting it back in. After scraping all that out, cleaning the core and light air pressure through the tubes, put it back together and now, 3rd gear chiseling deep or running a 16' disk it wont hardly get to 190 on long 1/4 mile pulls.
