My new 4020 has some hydraulic issues. The steering and brakes work good, but the remotes are very slow and will barely lift anything. First I checked the priority valve to see if it was stuck, but it was moving fine. Then we pulled the stroke control valve, which was stuck. We freed it up and thought that we had found the problem. Once we cleaned it out and got it free it lost all hydraulic function. Had absolutely nothing. The transmission screen is clean and the filter is new. The transmission pump is pumping. So after that we pulled the hydraulic pump out and put a used one out of his parts 7520 in it. When we started it up it sounded better right off the bat. It made the usual new generation pump noises. It steered nice and everything. So then it went to the swather. It still won't raise it. It will barely operate the endgate on the baler. Does anyone have any ideas to what may be my problem. I am thinking there may be a leak somewhere in the steering or brake system that is taking the pressure away from the remote system. I am about to pull my hair out with this thing. I am sure it will be some simple little problem once I find it. Any body else ever had any gremlins in their hydraulic system?
Thanks
Clayton
Thanks
Clayton
