Was setting the timing on my 36A with a timing light the other day and noticed a miss in the timing light as well as the engine. Shouldn't the light (and engine) fire EVERY time?
You can count the firing. Maybe 20 flashes then a miss or two. Very irregular.
Can the coil get weak? How do you test for this?
The points look clean. How can you tell if the condenser is ok?
You can hear an irregular miss going down the road too. The tractor seems to work well driving a thresher, but I think it could be better.
