Joe Reichert
Hello, wondering if anyone can help with this question. I have a JD 2030 year is 1973 that I split just behind the gear shifters or transmission. When you split there if you look at it toward the rear (where you split it or opposite of the shifters) you have a 4 bolt bearing support, which I'm attempting to remove. I took out 4 bolts and it loosened maybe 1/4 inch and then I cannnot get it out further. Is this a tough thing to remove? Is there a easy way or trick? Does it have a shaft that is making it difficult that goes to the rockshaft area? I wanted to take out and clean out a bit.
