my newly purchased 2030 2wd overheats after 2-3 hours light work.
i have removed rad and cleaned and flushed, this helped a little, also new thermostat.
water pump pulley has around half inch of play not sure if this will cause overheating.
also when you pull stop button the engine stops instantly as if stalling it, i wonder if there is anything that could be putting engine underload?
thanks Brett
thanks Brett
