I have a 63 3010. Had it about 4 years and has been a good runner but last year started showing these problems.
Will not restart when hot. After running a few hours, if you were to shut it off it to switch implements, it would not restart. Come back a few hours later and it would fire right up.
Hard starting when cold. If you didn't get it the first crank, it would be very hard to start. When it did fire, you would have to slowly give it a little more throttle at a time, or it would quit. Once warmed up, it runs like a champ. It is parked in a heated shop, so it not a cold temperature thing. Plugs look good, seems to have good blue spark.
Here are a few pics of the carburetor that is on the machine. Want to get into this now that the weather is starting to warm up but not quite sure where I should start.
Thanks
Thanks
