3020 elec-hyd problem
farmeroz
03-08-2012 12:19:47
Having trouble with the starting systmen on the 3020 gas. It will spin the motor great for about 5-10 seconds then slow down as if the battery is going dead. I have replaced the starter, battery and all the cables. I have tried isolating the starter for cranking but still the same problem. Could the hyd system be causing it to slow down? In the past I such a problem and repacing things cured it. Along with the starter problem is a steering problem that I posted on a litte while back. I have not gotten to the binding of the steering yet. Is there an easy way to bypass the hyd flow on start-up to see if that is a problem.
Tx Jim
03-08-2012 13:02:47
 Re: 3020 elec-hyd problem in reply to James L. Chard, 03-08-2012 12:19:47
Destroking screw(Parts key #6) if your tractor has a hyd pump with no serial number tag. AR33249 SCREW,HYD PUMP SHUT-OFF,ASSMY/FIELD ADD 15.48 USD third party image
farmeroz
03-08-2012 15:27:18
 Re: 3020 elec-hyd problem in reply to Tx Jim, 03-08-2012 13:02:47
OK TX and thanks. It has no relief valve so will check with local Deere.
