Help ID of a JD tractor
Tx Jim
Please can anyone can help me identify this JD tractor. The owner is in France and states it's a 303 but no JD parts catalog for a 303. I'm not familiar with a 710 but I thought that's what it is except the engine is incorrect for a 4 cyl Mannheim tractor. The air intake,exhaust manifold & lift pump are on the opposite side of engine .Thanks for any help,Jim
Maybe a repower engine? Look at where the engine attaches to the clutch housing. The plate on the engine looks like it was cut out with a torch. Possibly a homemade adapter plate? I have never seen an engine like that one.
(quoted from post at 09:04:33 02/27/12) Maybe a repower engine? Look at where the engine attaches to the clutch housing. The plate on the engine looks like it was cut out with a torch. Possibly a homemade adapter plate? I have never seen an engine like that one.
I agree as I've never seen an engine that remotely resembles it. I'm trying to help a man on another tractor forum from France determine why it won't start.Thanks,Jim
There was a model 303, built in Saran (France). I believe that Saran built their own engines (not sure whose design it was).
I'm out on this one. I can remember hardly any numbers from Euro tractors. That doesn't look like any deere engines I've ever seen before though. Good luck
Just a guess. Gotta 10-20 series hoodline, but they never made a smaller tracto until after the -20 series started, and the 1020 and 820 were 3 cylinder.
TX JIM
i believe what you have is a repowered lanz 300 or 700, it looks to me like the clutch housing has been cut down and the hood repositioned, on a 700 or 300 lanz the battery should sit on the cluch housing just like a 510 or 710, 510's and 710's rear sections are almost identical but if you look at the footboards you can see its a 300 or 700 lanz
thats my opinion, i have a restored 510 if you would like pictures of anything
PeterE
That's exactly what he states it is but does anyone know the parts catalog number as I can't locate one on JDparts.com? Does the engine have glow plugs or manifold heater??Thanks,Jim
The manual mentions a pre-heat on the ignition key (pressing in? my French isn't very good).
The wiring diagram shows glow plugs.
Jim
doing a little google searching it is for sure a john deere 303 tractor, what i believe i have translated from some french sites and checking some pictures in google the engine is a standard motor 23c, which is the same engine as a Massey ferguson MF35, u can see this by typing standard 23c motor into google. As for the starting aid i am unsure of the wiring because i cannot see the picture clear enough but judging by some of the masseys ive seen as well as the parts manual for my 510, the tractor probably has a flame start setup on it like many other european tractors
For political reasons, for a number of years, Deere had to put So. African "manufactured" Perkins engines in Mannheim built tractors destined for So. Africa. Perhaps this is one of those.
Thanks for all the help. Everyone's replies is one of the reasons I think YTMAG AKA Yesterdays Tractors is the "best tractor site" on the planet!!!!!!!!!!
Looks like a Standard diesel [British] used on little Massey Furgusons. As Cliff said looks like a adapter plate joining everything together. JD-Lanze tractors were 300's, 500's, & 700's, the 3&5's being 3 cylinders. They later became the 310, 510,& 710 with the 5&710 being exported to Canada in the late 60's. They were a Lanze tractor with a Saran built Dubuque designed 151 cu in & 202cu in engines. The next series were the 920,1120,&2120 exported worldwide except for the US......Ron
(quoted from post at 19:59:58 02/27/12) Looks like a Standard diesel [British] used on little Massey Furgusons. As Cliff said looks like a adapter plate joining everything together. JD-Lanze tractors were 300's, 500's, & 700's, the 3&5's being 3 cylinders. They later became the 310, 510,& 710 with the 5&710 being exported to Canada in the late 60's. They were a Lanze tractor with a Saran built Dubuque designed 151 cu in & 202cu in engines. The next series were the 920,1120,&2120 exported worldwide except for the US......Ron
just a side note, i believe the 300, 500, 700 tractors used 1010, and 2010 motors, and the later 310,510, used the 3.152 diesels and the 710 used the 4.202 engine
ya heres the specs for a standard 23c diesel engine
Type: Standard 23C
Fuel: diesel
Aspiration: natural
Cylinders: 4
Displacement: 137.89 ci [2.3 L]
Power: 37.25 hp [27.8 kW]
Cooling: liquid
Compression: 20:1
Firing order: 1-3-4-2
learn something new everyday :)
Peter,
You have a tractor that was indeed manufactured by Deere from 1961 - 1966...the engine is of the size and type that should be in the tractor.
A collection of three farm companies - Rouseaux, Remy and Thiebaud - created the CCM 1 prototype tractor in "61. A second prototype was created, but never produced because Deere joined the group and built a new factory in Saran. That factory opened in "62. The 303 was produced a year later for the French market.
The engine - the one you have - is a British Standard-Triumph diesel. This was one of the first Deere / Lanz tractors to drop the John Deere-Lanz plate in favor of the John Deere name alone.
