Tx Jim -JD 2940 starting problem
Randy G
02-22-2012 19:49:07
third party image
Jim, will this wiring diagram fix my "clicking" problem on my 2940? Got the kit from Deere but no posts are marked on the solenoid. With this diagram i will move the small wire from the starter to the
Tx Jim
02-23-2012 03:58:53
 Re: Tx Jim -JD 2940 starting problem in reply to Mike M, 02-22-2012 19:49:07
Appears to me that is exactly the way I tried to describe to you to wire the added solenoid in one of my previous posts. I'd suggest using at least 12 ga wire from starter to added solenoid.
I will remind you to have a very good ground attachment for the added solenoid. Back when I worked for a JD dealer several service calls were made on late model 3020/4020's for no starting that the extra solenoid had simply lost ground.
This post was edited by Tx Jim at 04:25:58 02/23/12.
Randy G
02-22-2012 19:54:36
 Re: Tx Jim -JD 2940 starting problem in reply to Randy G, 02-22-2012 19:49:07
With this diagram I will move the small wire from the starter to the solenoid and run a wire from the battery post on the starter to the solenoid.
