I’ve searched and read as many posts as I can find on the topic of going from 34’s to 38’s on a 4020. The 4020 has 3 3/8” diameter axles. I understand that there are step up wheels that will utilize my original cast centers and then I have seen where there are cast centers for 38’s. I have a set of rear cast wheels and rims that are 38 inch and well weighted. They are casting number R41020 the axle wedges that are with these wheels have a larger axle bore like 3 5/8” or so. The 4020 wedges won’t work in the R41020 wheels the tapered hole in the center of the 38” cast wheel is larger. My question is does John Deere make wedges for the R41020 wheel with a 3 3/8” axle bore so I can use them on the 4020 :?:
