G undersized rod and main bearings
jlg
01-23-2012 07:34:14
I have a 1950 John Deere G. One rod journal had previously been turned down to .030" under, and the main"s should be round at .010"under. The main bearings are the split type that are adjustable with shims.
#1- anyone know where to find .030 under rod bearings?
#2- assuming I find rod bearings, is .010 under on the mains too much to make up for by removing shims?
430WLPG
01-23-2012 10:47:13
 Re: G undersized rod and main bearings in reply to jlg, 01-23-2012 07:34:14
Get in touch with one of those guys that repour rods and they can repour your mains thick enough for the undersize crank you just have to tell them what you need
Mike M
01-23-2012 10:12:30
You may also find std. ones and have the crank welded up ?
jlg
01-23-2012 10:00:09
Found .030 under rod bearings. Now just have to figure out the mains. Any ideas?
teddy52food
01-23-2012 08:22:40
If it is to be turned .010, get .010 inserts. Removing shims leaves an egg shaped hole & not much bearing surface for the crank to wear on. Check with the machine shop that does the crank for the bearings.
naylorbros
01-23-2012 08:53:53
 Re: G undersized rod and main bearings in reply to teddy52food, 01-23-2012 08:22:40
Good luck on finding .010 inserts for the main bearing. If I remember no one including Deere offered anything besides STD for the main bearings.
jlg
01-23-2012 09:44:33
 Re: G undersized rod and main bearings in reply to naylorbros, 01-23-2012 08:53:53
Right. Only standard mains from Deere. I looked on the archieves here to see what others had done and never really saw an answer. I agree though, it seems like just removing shims on the standard bearings would leave me an egg shaped crank. As for the other bearings, I"ve found lots of places, including Deere, that have .020 under only. I was just hoping someone on here might know another source. Don"t hurt to ask.
Kent Petersen
01-23-2012 12:28:00
 Re: G undersized rod and main bearings in reply to jlg, 01-23-2012 09:44:33
call Gaffrey Babbiting in Deadwood SD he can make them
