1650 swinging drawbar
Szrachnor
Anybody know of another John Deere drawbar that will fit the 1650? Mine's missing and it's discontinued from Deere.
The latest part number for the drawbar for a 1250, 1450 and 1650 are all the same, CH20112. However it is a different part number that the CH20112 subs for in each tractor. So, I'm guessing that if you find one off a 1250 or 1450, it might work on your 1650. Maybe you'd get lucky and find a 1250 or 1450 being parted out that has the CH20112 parts-replacement drawbar. I don't know, it may be the 1250, 1450 and 1650 original drawbars were all the same dimensionally, but the difference is in the steel or hardening. It doesn't look like it would be too hard to make one if someone would be good enough to supply you with dimensions. It's simply a straight piece of bar stock, all-be-it probably hardened, with five holes in it. These tractors were made to JD specs by Yanmar in Japan.
