Unstyled John Deere B vs. Unstyled John Deere A
Jim Blakeman
12-08-2011 15:20:32
I am preparing to purchase my second John Deere tractor. I had a '37 Unstyled B that I really liked. It will be a toy/light work tractor on my five acre mini farm. What are the major differences between the A and B, please.
Signed, Eager to learn.
The Dukester
12-11-2011 17:39:44
 Re: Unstyled John Deere B vs. Unstyled John Deere A in reply to Jim Blakeman, 12-08-2011 15:20:32
I've ran 'em both doing a lot of different jobs and generally speaking, An A is almost twice the tractor a B is. Plowing the A pulls 2-14's relatively easy anywhere while a B has all it wants with a 1-16 and just plain struggles with 2-12's. The A will pull an 8 foot double disk or a 4 section springtooth harrow and get something done. A B has a tough time with any double disk wide enough to cover it's wheel tracks. An A can pull a PTO small square baler...with a wagon loading, not so with a B. Thing with an A is you gotta put weights on it's rear spoke wheels or load the tires to do heavy work....I prefer the weights myself. In tall corn an A can go twice as fast as the B doing a real job of cultivating with a 2 row unit. Don't get me wrong...a B is useful...but it's underpowered a little for it's physical size...an A isn't, it's simple as that.
Jim Blakeman
12-14-2011 15:35:15
 Re: Unstyled John Deere B vs. Unstyled John Deere A in reply to The Dukester, 12-11-2011 17:39:44
Thank you so much for you info.
Jim Blakeman
12-09-2011 06:55:11
Thanks to all who replied. I think I want an A now because it has a little more power.
Pete in MD
12-08-2011 19:13:59
Basicly the same except for size and horsepower. The B was rated at 15 hp and the A at 24 hp.
BushogPapa
12-08-2011 18:29:37
If you plan to put either to work, remember they both have a fast 1st gear. The US "B" will be most likely to completely run out of power in 1st gear.. Now, either one can be improved, Power-Wise..as much as you could want..but it does cost money.. Later JDs have a much slower 1st gear that is very handy for heavy work like using a blade on a loader or pulling brush out with a chain, etc.. Either of these US tractors will be slow,
traveling on the road.. Take your pick..!!! Ron.
Larry Baker
12-08-2011 17:27:07
Luv them both but good luck finding a good one-bottom
Old Popper
12-08-2011 16:13:06
Like the difference between the draft horse and a saddle horse. They're both horses, but one is heavier and stronger than the other.
Jim Broughton
12-08-2011 16:05:22
Yeah, they are both good and do operate the same, however if you are gonna plow in confined spaces, like a garden plot,etc. the "B" handles easier with a one bottom plow, the "A" usually will pull a two bottom plow, which is harder to handle in tight spaces.
Best of luck !
Jim B.
DScott
12-08-2011 16:00:25
 Re: Unstyled John Deere B vs. Unstyled John Deere A in reply to greenday, 12-08-2011 15:20:32
Yep, I agree with CLW. The unstyled B is pretty much a 2/3 scale unstyled A.
CLW
12-08-2011 15:28:50
 Re: Unstyled John Deere B vs. Unstyled John Deere A in reply to rytre, 12-08-2011 15:20:32
Size only. Everything looks and operates the same. I like the sound of the A a little better.
