upper water pipe for US B
n29we
I'm restoring an early US 4 bolt center fill B that needs the correct upper water pipe. The pipe needed does not have the temperature probe hole in the casting. I'd appreciate any help in locating one for this project. Thanks JimO
I would check at wwww.oldjdparts.com..or
www.external_link.com.......OR You may be able to match up the O.D of the pipe that you have with some galvanized exhaust pipe or any other pipe that you can find at your local auto parts stores. Cut the old out and weld in new....
