626 gator
jim avis
10-10-2011 17:44:50
I purchased a 626 gator with a bad motor, i could not afford to purchased a new motor, i found that a 420 cc motor, electric start, from harbor freight, $299.00, 54.00 for a 2year replacement warranty,went from a 9 HP to a 14HP the only change i made was the exhaust pipe had to be cut and turned, the air cleaner hose redricted, addes a electric fuel pump with a pressure reg, gas cable stayed the same. i did moved the battery of front of the motor so thaat all electrial cables fit,
