Thought I was almost done with the resurrection of a 1975 2030 gas tractor. Started out with the motor stuck. Tore it down and sent the head out for rework. In the mean time, I replaced the pistons and sleeves and got it all back together last weekend. Started it up and it ran pretty good.
Tried to start it the next day and it was very hard to start. When it finally started it sounded like it was running on only about 2 cylinders. The valve train made some horrible clunking noises so I immediately shut it off.
Pulled the valve cover and found 2 push rods badly bent and 2 slightly bent. The 2 badly bent were on intake valves as was one of the others. I now have the head off, again, trying to find out what went wrong.
Has anybody else had such an experience? I'm not sure what caused this nor what to do to prevent a recurrence. I'm hoping to get some advice from some of you guys that know way more about this stuff than I do.
Thanks,
Blaine
Thanks,
Blaine
