clayshootr
I just started farming again this year. Our place has about 160 ac of tillable ground. My primary tractor is a 720D with pony start, which is a 6 volt system. This year I only planted 45 ac of soybeans and did not use the monitor (JD 7000 series 4 row), but next year I am going to farm it all and plant part of it to corn and will need to put on liquid starter fertilizer and run the monitor. I am also fixing up a spryer and wanted to put a foam marker system on it. What would be the best way to run all these 12 volt accessories with this tractor short of trying to find a 3020 with a 12 volt system??
Thanks
TJ
Thanks
TJ
