Got the NOS block on the tractor today and after getting it running I was hearing a random clunking noise, like something was rattling loose, coming from around the belt pulley area.
This noise is not new, just seemed louder today and with just putting the front end back together I was paranoid.
I took the clutch apart and notice if I turn the belt pulley back and forth a little I could hear and feel the belt pulley gear against the spline gear, just a little tic, tic, tic as I rotated the pulley back and forth. I don't think this is what is causing the clunking noise I am hearing when it runs. I then took off the belt pulley spline gear cover and noticed the spline gear wobbles a 1/4" and I can push and pull the whole spline gear assembly in and out an 1/8" or more.
How the hell did the spline gear or shaft get bent and should I be able to push pull the gear assembly that much.
I thought about running the tractor with out the belt pulley on it to see it the noise went away and if so then running it without the spline gear. Can I do this?
Your help is greatly appreciated,
Bruce
Bruce
