Company Logo (800) 853-2651 Shop Now
jd 4020 Power steering leak
Den H
08-13-2011 04:13:10
Actually not sure what this is. A tube (1/4") that is located above the front wheels has a leak (pin hole)and is shooting hydraulic fluid. Any ideas? Is this something I can take care of?
Thanks
Dennis
Tx Jim
08-13-2011 04:21:25
 Re: jd 4020 Power steering leak in reply to travz500, 08-13-2011 04:13:10
Is the 1/4" tube made of plastic?
Den H
08-13-2011 06:29:37
 Re: jd 4020 Power steering leak in reply to Tx Jim, 08-13-2011 04:21:25
No, it's steel. I took a pic but can't figure how to put it up here. It's a steel tube running left and right just above the steering arm tie rods. I can't see where either end goes to or from.
Tim S
08-13-2011 06:35:44
 Re: jd 4020 Power steering leak in reply to Den H, 08-13-2011 06:29:37
It's a steering line that takes the pressure over to the other end of the steer motor, yes you can remove it, but if you have a wide front you may need to drop it down to get to it, they get a bit rusty under there, rock the fitting a bit to see if it will free up,if it's rusted stuck put some head on it first, you can braze the hole shut and re-install the line.
Den H
08-13-2011 07:03:49
 Re: jd 4020 Power steering leak in reply to Tim S, 08-13-2011 06:35:44
Thanks Tim, Yes it is wide front.
Do you know if there are any repair manuals that are better than others. I am really green on this and I don't mean JD green.
Den H
09-17-2011 05:28:36
 Re: jd 4020 Power steering leak in reply to Tim S, 08-13-2011 07:42:13
Hey Tim, Thanks for the great info last month. I lost your email in the interm. I could use just a little more info on the front end removal. Have the long bolts, do you think I should pull the tie bars or remove the bolts that attach the bars to the steering hub? The bolts on the hub seem to be the way to go. Won"t damage the tie bar ends that way. What do you think?
Thanks
Dennis
Tim S
09-17-2011 07:13:55
 Re: jd 4020 Power steering leak in reply to Den H, 09-17-2011 05:28:36
I remove the tie rods,if you turn it each way till it stops you can get to them easier, once you get the nuts off(there should be a cotter pin in there too)hit the steering arm(not the tie rod)strongly on the edge this will pop the tie rod off with out damaging any thing,the theory of this idea is by hitting the side of the hole area it distorts the tapered hole to allow it to pop out, almost like magic...
Den H
09-17-2011 09:31:37
 Re: jd 4020 Power steering leak in reply to Tim S, 09-17-2011 07:13:55
Thanks Tim. I'll give it a try. Always used the fork on cars and it really tore the covers up.
Tim S
09-17-2011 10:06:17
 Re: jd 4020 Power steering leak in reply to Den H, 09-17-2011 09:31:37
Yes the forks don't work very well, this "Hammer" way works good, as long as you can get a good shot at it.
Den H
08-13-2011 08:29:20
Thank You Tim...I really appreciate it!
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once ... [Read Article]
Latest Ad: Square axle jd B complete tractor not stuck but doesn’t have to run looking for a project thanks [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
