I have a 2550 with a 8x2 transmission. When round baling at PTO speed, I encounter quite a bit of grinding when shifting from neutral to low with the other lever in gear. The clutch seems correct in terms of free travel and I have it pressed in fully for the shift, with the tractor completely stopped. What seems to help is to put the right shifter in neutral, set the L, then shift back into 1 or 2.
I was told that the clutch was replaced by the dealer around 4 years ago. Operation seems normal (but occasional grinding while shifting) when at lower RPM. It kind of feels that the clutch is not fully stopping the geartrain for the shift.
Is some grinding normal for this tranny? Any advice? I read the manual and the only thing they emphasize is be stopped to shift H/L.
Also, should this tractor have a greaseable throwout bearing? It shows one in the manual but cannot find the zerk in the access port.
John
John
