My “new” John Deere L
alabamafrog
Here are some pics of my newest family member and some pics of missing/broken parts that I have found so far;
Anyone got a line on any of these missing/broken parts?
Rusty Acres Ranch or the Ridenours for parts. Looks like an
early L with the Hercules motor and top shift tranny. Not sure
what that clutch system is in there but it doesn't look right to
me. Repro chins and sheet metal are about the same as good
original parts. Not sure if that aircleaner is right either.
Usually they are mounted on the other side of the hood. Nice
find though with the cultivators and solid rims.
Nice Find!! I have a bearing and seal kit for the tranny in that L and if you need one I'll make you a good deal on it.
Nice find. Its hard to find L or LA with tags intact.
Steve Ridenour is the leading expert when it comes to these
tractors, he has helped me alot with my LA. His reproduction parts
are top notch, but can cost.
mark
(quoted from post at 12:49:30 07/04/11) Nice Find!! I have a bearing and seal kit for the tranny in that L and if you need one I'll make you a good deal on it.
Thanks for the offer, when I get a chance to work on it and see what all is wrong I'll let you know if I need those parts.
Anyone know anything about that big gear hanging out of the clutch housing?
I am thinking that may be a part of a pto assembly? Kinda looks like some of the parts for the LA PTO. It wasn't offered for the L's but I am sure it could be easily bolted on to one. See PC151 from jdparts.com for the LA PTO parts break out. I could also be wrong about that air cleaner being on the wrong side. The L parts book shows ser. # 640000 & up having the air cleaner on the carb side of the tractor with three options for the L air cleaner.
Looks a lot like the day my LA came home!
