Here's the rundown:
Bought this tractor a little over a month ago. Ran pretty well aside from no low idle. Used it for about 30 minutes and then it started lugging. Topped off the gas assuming it ran out. It ran like crap after that.
So. I pulled the the carb, everything looked great. Thought it must be E10 making it run poorly, replaced the gas, then it started flooding itself, firing up, running poor, shutting off. So I ditched the electric fuel pump the previous owner rigged and put a Lifte pump back on. Also switched to electronic ignition, replaced plugs, more gap, etc. Now it fires right up, runs for a few seconds and shuts clean off. Fuel bowl isn't empty, still has spark when I try restarting. So then I started cleaning up the wiring nightmare the previous owner left me with. Now it starts even stronger, I eliminated an issue I had with the starter tripping itself, but it still won't stay running, sometimes it shuts off with the starter, it don't run without the starter.
I bypassed the breaker, ignition switch, you name it. Still won't work right.
Please someone tell me what I'm missing.
I was positive it was an ignition issue since it just shut off with no sputtering, but i have spark still. One of the advance springs in thr distributor is broken, and it was in rough shape so I'm waiting on a new dist.
When.it.does fire up and run without the starter staying on, it won't restart for a while. Can't be condenser since I went electronic. Maybe I'm just now getting enough spark and it's a tired dizzy?
Any and all ideas welcome.[/u][/list]
