JD Bog?
Craig C
06-08-2011 03:47:21
What model JD offset disk is considered a bog disk. I looked at a 340 and decided it was just a heavy disk nothing special. I was looking on Tractor house and looked at a JD 425 offset. Is that A bog that can take more abuse? Need to be able to cut through reasonable size green limbs and roots. I would like to be able to pull it just after bushhoging some grown up ground. Even better pull it with the D6D and eleminate the worry of flat tires, because some of the trees are thorns. Farmland is at a premium nowadays!
