ok, I parked my 51 AR and my 52 AO side by side and did a comparrision. I remove one componet at a time and inspected both of them. I have believ I have discovered what is causing my problem. The clutch drive on the AR is not on the crank far enough. It over hangs the crank by .130". The clutch driver on the AO over hangs the crank by .010". I can swap the drivers around and the dimensions remain the same on each tractor. This actually confirms that what i beleived prior to this. When you disengage the pully it travels to far back and engages the outer friction plate to the clutch driver.
Now, does any one know how to rectify this problem with the clutch driver? I have inspected every thing and can not find a burr or any deformation on the crank causing the driver not to properly seat itself on the crank. Any help will be graetly appreciated. Thanks
