On my 1951 John Deere AR, when I pull the clutch back to disengage it, it does not release. I can drive uphill, down hill, or on the flats with it disengaged.
What I have done: I have replaced all the friction plates, clutch driver, and even the pully assembly. It still makes no difference. I have determined that what is happening is that the pully has too much travel on the crank shaft. For trouble shooting, I have loosened the brake up and when I pull the clutch back it travels to far on the crank cuasing the outter friction plate to grip the driver and keep it engaged. If I loosen the clutch plates up there is not enough tension to engage the clutch. I have measured the backlash on the crank shaft and set it to .005 play. What am I missing here? Is something worn on the crankshaft or the bearing housings? I have also made this same comparissions on my other trators and none of them have this problem. Any help would be greatly appreciated. Thanks
Before I get the "buy a manual" answer, let me say I have them. I have alot of them. I have every manual that was produced for each of my 13 John Deere tractors and many more for all the implements that I also have. Half of my tractors have been torn down and rebuilt 100% from the ground up. Kind of an expensive hobby. I like to tell every one that they are "Green Harley Davidsons". Any help / ideas / advise would be grately appreciated. Thanks in advanced.
