HWooldridge
While working on my recent 2020 engine overhaul, I also replaced the clutch disk and throwout bearing (since the tractor was already split) but I left the pressure plate as-is. All three had visible wear: the disk was almost down to the rivets, the throwout had a slight groove in it and the ends of the levers on the pressure plate were also worn.
I reassembled the tractor, started the engine and ran it for a few minutes according to the break-in instructions then got in the seat and tried to put it in gear. It would not drop in and the gears clattered so I knew the clutch wasn't releasing but figured it would be easy to adjust from the access port on the side. I pulled the clips and ran the adjustment screws in and out to their limits but nothing I tried will fully release the driven disk. I can see the pressure plate moving but it just doesn't travel far enough.
My questions are:
1. Which direction is correct for the adjustment screws when adding newer, thicker components. It sounds logical to tighten the screws, which raises the levers - but I ran out of travel before they released.
2. The pressure plate seems to be in good condition so should I try to replace the levers or just buy a new one? The manual seems to reference rebuilding it but my local JD dealer may want to sell me a whole assembly.
My questions are:
