bmiller36
I bought a G last fall and it runs fine but has a lot of endplay in the flywheel. what type of wrench do I use to get the flywheel bolts loose. I have a flywheel wrench that works on my open flywheel tractors but not on the G. Need advice on this one. Thankyou Bob.
If the regular flywheel wrench won't work for you I would use an old box end wrench. Cut to length and weld a socket to fit an extension bar,preferably 3/4 inch. Hope this helps. Ron Mn.
