1946 JD B clutch adj.
Jim Sanders
04-03-2011 18:13:10
Clutch lever will not stay in gear. Tried tightening the 3 adjusting bolts. No change. Could this be somethinga major? Thanks.
Dutch JD lover
04-11-2011 13:24:52
 Re: 1946 JD B clutch adj. in reply to Jim Sanders, 04-03-2011 18:13:10
hey sanders i"ve exact the same problem.
how have u solved the problem?
Pappy
04-04-2011 07:22:22
Does it snap in when you push the lever forward?
If not, you could possibly have the clutch adjustment too tight already.
Jim Sanders
04-04-2011 12:35:51
 Re: 1946 JD B clutch adj. in reply to Pappy, 04-04-2011 07:22:22
When you push the clutch lever forward, there is a very slight bump felt when it goes forward. Then it vibrates back out of gear. There is a cotter pin through each adjusting bolt/nut to keep it tight. Thanks
Meangreen
04-04-2011 05:56:16
I would guess it has something to do with the fork on the backside of the clutch assembly. To pull it out you remove the panel next to the cluch pad and it will pull out.
Or it could possibly be worn clutch pads, but you would still be able to produce the pop, but the tractor just wouldn't move (when running) or would move much slower than normal.
I would start with the pads because they are the easiest thing to begin with.
BushogPapa
04-04-2011 05:48:56
Why was there no change..?? Are the threads worn so badly that the nut is just slipping over the threads..?? To see for sure, you could temporarily double-nut, or washer the nuts, to see if they engage the threads better.. BUT, if they are worn that badly, the BOLTS AND the Nuts need replaced...
Ron..
