Finally got some time to tear into the 420T we picked up last summer.
At the time we aquired it, it had been sitting for 20yrs. Louisiana, under a barn eve. Engine turns over fine. I have pulled everything off of the front. Hyd pump, alternator, water pump, ect. Rebuilding all of it, and replacing all seals and gaskets. It had a leaking frt main seal, and while I was replacing that, I decided to do the above since its all so easy to get to with the front end off.
Do yall think I should pull the head? I dont have any reason to think that the head would be cracked, and the entire unit was holding coolant fine.
Head gasket in question I guess is the only thing im thinking.
We are very good freinds with the previous owner, and there was nothing actually wrong with the unit at the time he parked it.
Thoughts?
Thoughts?
