HWooldridge
Awhile back, I posted a couple of times on resleeving a JD 2020. The general consensus then was to split the tractor and pull the engine for an overhaul. I've done that and am now ready to hang the engine on a stand but mine is only rated for 1000 lbs and the arms won't spread far enough to fit the bolt pattern. I am confident I can fab some new arms but was wondering if anyone can provide the dry weight of a 4 cyl, 202 ci diesel. I'd rather not buy another stand unless absolutely necessary since I probably won't use it for another ten years...<LOL>.
In addition, where is the block casting number usually located? I can't find anything in the manual to reference it.
Thx, Hollis
Thx, Hollis
