HWooldridge
I've posted a couple of times in this forum about the coolant dump on my 2020 and moving it to a suitable work location. I finally received the TM-1044 manual today and was reading thru several chapters on the engine but have a question or two prior to tearing into it.
It would be pretty difficult to pull the engine in the barn so I would prefer to do an in-frame overhaul if possible. That said, I was planning to drop the pan, crank, rods, pistons, etc from the bottom then pull the head and remove the liners. I know there's more to it than this but is that basic sequence correct?
In addition, since it looks like this engine was never overhauled, I'm concerned about how hard it will be to remove the liners and was wondering if they might be stuck to the point of needing a hydraulic press to move. Of course, I suppose I could turn a piece of wood and press them from the bottom with the floor jack if necessary but I'm hoping that won't be necessary.
Any comments or suggestions are appreciated...
