bigfatricky
New User
Howdy all--
Thinking about buying a 3010D. Everything checks out for me on the tractor but there was one thing that prevented me from handing the guy a down payment today.
When I engaged the pto, it was a little noisier than I would have liked. I was having a hard time pinpointing where the noise was coming from, but it was in the area of the 2 bolt plate that covers up the pto throwout bearing or from the pto shaft that comes out right near it. The noise was a little quack that seemed to be in sync with shaft rotation. The throwout bearing did have a little play on the shaft, but I can't judge if it was excessive because it was the first time I had ever looked at this setup. I looked at my neighbors 3020 and his same bearing had a similar amount of play.
The noise DID seem to decrease as the fluid warmed up (outside temp was in the upper 20's) and the hydraulic reservoir was low on fluid (wasn't even touching the dipstick, but we brought it up with a few gallons).
I am aware of the pto issues with the 10 series tractors, but I am feeling good about that topic with this one.
I am buying this tractor for reasonably light work. It will need to run a 24T baler and other lighter 540rpm chores like brush hogging and 3pt tilling. I will never be using it for any 1000rpm duties.
The tractor is in really good condition otherwise, which I view as a sign that it was well taken care of. My hesitation is that I don't want to run into a tractor split a few hundred hours after it gets home.
Anyone with a 3010 or 3020 that can offer a few cents?
Thanks everyone!
Thanks everyone!
