primer question
ArnieinChesterfieldVa
12-19-2010 09:55:18
I'm off work til Jan.3rd so I reckoned it a good chance to get something done on my 60. Thought came to mind of getting some painting done....like the 3-point setup, toolbox, front bracket, etc. For final John Deere green paint, I'm going to the dealer so I'm not taking a chance on using the Valspar paint that might turn a blue shade later. I'll use the Valspar green and yellow on implements that don't matter so much.
My question is that I also have the Valspar primer from Tractor Supply. Do you think that primer will be good enough or should I buy the actual John Deere primer at the dealership also?
Thanks,
Arnie
RamRanch
12-19-2010 10:51:57
 Re: primer question in reply to ArnieinChesterfieldVa, 12-19-2010 09:55:18
I would use the John Deere primer if your going to use the John Deere paint. RR
12-19-2010 16:20:42
 Re: primer question in reply to RamRanch, 12-19-2010 10:51:57
Well, Maniac, I have no idea who makes the paint for John Deere..... ..but I will check out the archives like you suggested.
Thanks, guys.
B-maniac
12-19-2010 12:33:38
What makes you think Valspar doesn't make JD paint also ?? JD doesn't and probably never has made paint. You might want to go over to the paint and body section on this forum and research the archives or post your Q. You might be surprised.
