Uses for an LUC power unit. Any suggestions?
Randy G
10-29-2010 06:39:35
I bought a non running LUC hand crank power unit as a project. (i like to bring life back in to things like this) When I brought it home the wife asked "What are you going to use that for?" Well, my only response was "Enjoyment!" Well, that didn't fly very well but made me wonder what I could do with it. It has a belt pulley out the back of the motor. Any suggestions? Thanks for your help.
teddy52food
10-29-2010 17:35:44
 Re: Uses for an LUC power unit. Any suggestions? in reply to Randy G, 10-29-2010 06:39:35
A friend of mine has one on a wood-splitter.
PJH
10-29-2010 09:12:43
Here's an idea.
PJH
10-29-2010 09:14:58
 Re: Uses for an LUC power unit. Any suggestions? in reply to PJH, 10-29-2010 09:12:43
third party image
Try agin. . .
Smarty pants
10-29-2010 20:06:09
 Re: Uses for an LUC power unit. Any suggestions? in reply to PJH, 10-29-2010 09:14:58
I like the head rest..... ..looks comfortable.
thesmoothedeere
10-29-2010 10:52:50
Wow .... What a women ...
jd b puller
10-29-2010 07:21:05
I'd go to Harbor Fright and get one of those generators and couple it up to that. Be sure you check the HP requirements.
I've got some 3.510" pistons for one if you need them.
usetabesteve
10-29-2010 07:05:43
They were used on combines and balers when they were new, and you could run a small sawmill with one. Carnival equipment was more often run with a Farmall or AC four cylinder engine.
Once you explain to your wife that you will need to buy a combine she might be ok with letting you run it just to hear it. The best thing I could think of for now would be a bank of ice cream makers. Look at Wardner's project on the Farmall page.
