Anonymous-0
Got my new 5075M and is the glow plug system ambient temperature dependent? In starting it the last couple mornings (temp in low 40s), I moved the key to the position to activate the glow plugs and nothing happens. From what I can tell I have the deluxe dashboard and there should be a 30 second count down. Nothing luminates on the dash indicating glow plugs are working. Thanks for the help.
I can't answer your question but I'm wondering why JD has deemed it necessary to use glow plugs for starting a diesel engine? Maybe has something to do with EPA
JD diesel engines didn't require glow plugs for a starting aid since the 1010/2010 failures back in the early 60's
I will add that the glow plugs are reasonably priced
Part Number: RE505867
Part Price: 14.25 USD
Description: GLOW PLUGS
