A friend of mine has a 1959 JD 730 and we are having some problems with it. To start off with, it is low on power. It has about 35-40 HP on the dyno at rated rpm. It seems like it is getting way too much fuel. Has a fair amount of black smoke coming out when you load it down to 40 on the dyno. The most HP we could get out of it is about 45. In 6th gear you can just about kill it when you apply the brakes. And we left the fuel shut off in the off position by accident when we changed the fuel filters. When we started it, it ran for about 15 seconds and started to load up with fuel had a lot of black smoke and then died.... ???
So far we have replaced filters, cleaned out the intake and changed the oil in the oil bath. And we have also adjusted the rack to 13 according to the JD service manual we have. We also cleaned out the sediment bowl. Next we checked the transfer pump pressure... and this is were we got more confused. The pressure is supposed to be 12-24 psi, and when we checked ours we couldn't get a definite reading, the needle was all over the place at idle and when you went full throttle it got worse. What could be causing this? Any help or advise to our low power problem is greatly appreciated.
