Tractor is running fine, out baling, and the tach starts jerking around. Needle starts to bump down from set RPM 500 rpm or so and jerks back. bout every half second or so it jerks. Engine is running smooth and not changing rpm. I am thinking electrical connection corrosion in the wiring harness or perhaps an alternator issue. Have not dug into it yet. Is there a likely connector to check first for corrosion? Could it be the sending unit? Where would it be located.
This is intermittent. If it happens again, plan to put a meter on the 12v to see if I am getting a variable voltage from alternator. I am suspecting it may not be the alternator, however. Batteries are being kept well charged.
John
John
