JD B for pulling
alliswd45
09-26-2010 09:17:37
We're looking to build a B for pulling. Wondering what we could do to get good power out of it. Would it be possible to put A guts or bigger inside it? What has been done that works. Looking to take down some JD A's on the track.
brian r raml
09-28-2010 21:56:55
 Re: JD B for pulling in reply to alliswd45, 09-26-2010 09:17:37
i have a 51 b pulled 5 classes from 4 to 6500 lb won all 5 with two full pulls. stock crank power block and hiesler head stock carb and manifold out pulled g by 50 ft 560 farmall as well
jd b puller
09-28-2010 16:05:53
 Re: JD B for pulling in reply to Walt in Jaxn Tn., 09-26-2010 09:17:37
Yes, much better to restore them then put them in a barn with a cover on it. :roll:
machinery-man
09-27-2010 22:03:13
better put locking shifters in the transmission or it will jump out of gear....
gtx1967jewison
09-29-2010 13:38:08
 Re: JD B for pulling in reply to machinery-man, 09-27-2010 22:03:13
what a DUMB thing to say! if the tranny is in shape & set to specs no amount of power will pop it out of gear, & thats a fact!
jd b puller
09-26-2010 20:07:19
If you insist on bringing a knife to a gunfight, you need to bring a big knife.
To answer your question, yes, it's possible to put bigger "guts" into it than an A. It's possible to put bigger guts into it than a stock G.
E-mail for more info.
CLW
09-26-2010 19:25:30
 Re: JD B for pulling in reply to cnb, 09-26-2010 09:17:37
You know that won't cost much don't you. :cry:
B-maniac
09-27-2010 20:23:51
 Re: JD B for pulling in reply to CLW, 09-26-2010 19:25:30
Unbelievable how much one will pay for a big plastic/pot-metal trophy. Sheeesh...get a life. If testosterone don't kill ya it'll at least make you broke!
Kurt_JDB
09-26-2010 10:38:26
You will want to talk with my friend JD B Puller. He is making custom blocks and heads for the B, and is getting about 100HP out of a late styled B. I think he has it punched out over 400 cu. in..
I think that would be hard to beat.
Kurt
