JD5010 Engine
Mark A. Isringh
09-21-2010 15:06:49
What engine is in the JD5010 scrapper and what will work for a replacement?
Ole Shovel
09-24-2010 16:11:03
 Re: JD5010 Engine in reply to Mark A. Isringhausen, 09-21-2010 15:06:49
531 was in 5010, 5020, & 6030 which was turboed on most but a few without. 619 from 4x4 tractors and ensilage cutters will fit it was made in several hp ranges. There was Caterpillar V8 conversions using a M&W adapter plate put in some 5010 & 5020 also some may have got put in scraper tractors.
Tx Jim
09-23-2010 04:13:54
 Re: JD5010 Engine in reply to weightneeded, 09-21-2010 15:06:49
Tim
It's cooled off some since you've been down here. It's supposed to be in the high 50's in the mornings next week. I'm ready for some humidity to GO.
Tx Jim
09-23-2010 04:10:31
 Re: JD5010 Engine in reply to jd-tom, 09-21-2010 15:06:49
Same way JD engineers think a small block 276CID can replace a larger CID engine.He-He
I was thinking about the 180 pto HP of a 466 in a 4840
Aspiration: turbocharged intercooled
Cylinders: 6
Valves: -unknown-
Bore/Stroke: 4.5625x4.75 inches [116 x 121 mm]
Displacement: 466 ci [7.6 L]
BTW my favorite CW song is "I'm purty good at drinking Beer"
Tx Jim
09-22-2010 04:23:14
 Re: JD5010 Engine in reply to buickanddeere, 09-21-2010 15:06:49
531 cid & replacement 619 cid or 466 cid
4010 puller
09-22-2010 15:50:37
 Re: JD5010 Engine in reply to Tx Jim, 09-22-2010 04:23:14
how would a 466 be a replacement? One engine is a smallblock while the other is a big block.
Tim S
09-22-2010 18:04:26
 Re: JD5010 Engine in reply to 4010 puller, 09-22-2010 15:50:37
I saw where Jim called that one wrong,,I figured it was to much Texas heat...
4010 puller
09-23-2010 03:37:36
 Re: JD5010 Engine in reply to Tim S, 09-22-2010 18:04:26
maybe too many texas tea's...
