3020 starting issue
gary in neb.
09-20-2010 07:16:58
borrowed my friends 3020 diesel early model (controls on dash) and have been using it without any issues rain or shine. yesterday, a bit rainy/misty out, went to start it and it acted like t he starter engaged, then all was dead. checked wire connections at batteries, one seemed a little loose but not bad. for some reason, gen light (right light on dash) came back on, but would flicker and get brighter when i would jump the solenoid. battery voltage was a bit low on one, only had 11 volts so put the charger on, but to no avail. that was the left battery. right battery had 13 volts. i even tried jumping the solenoid but could not get it to do anything. am a little lost on 24v so thought i best ask here first.
thanks
Gary
Tx Jim
09-21-2010 05:01:17
 Re: 3020 starting issue in reply to ISU JD, 09-20-2010 07:16:58
gary in neb
I agree on the battery post cable loose or maybe corroded.
Starter gear(aka Bendix) may be stuck in flywheel ring gear from low voltage.
If it's a Syncro-range have you thought about tow starting? If powershift don't try tow start!
Tom 43
09-20-2010 11:36:16
 Re: 3020 starting issue in reply to jd parts guy, 09-20-2010 07:16:58
Take both batteries out and charge them. Take them somewhere where they have a load tester that will apply one half the CCA rating on the batteries for fifteen seconds. Voltage should not fall below 10 volts. if it does, you need a new set of heavy duty batteries. If this test is passed post again.
gary in neb.
09-20-2010 09:46:05
 Re: 3020 starting issue in reply to gary in neb., 09-20-2010 07:16:58
did not check the big terminal next to block and top of selonioid. else had 14 volts all over. red light on dash got brigther when you pushed the start button. acts like a saftey switch but they check out.
ET
09-21-2010 04:52:23
 Re: 3020 starting issue in reply to gary in neb., 09-20-2010 09:46:05
It sounds like you have lots of battery. If the voltage on the individual batteries doesn't drop below 9 volts when cranking or the combined voltage at the starter not below 18 volts they should be fine. I think you should take the through bolts out of the starter and pull the end cap off the starter. Then you can see the brushes, they are most likly worn down so the holder rests on the stop and the brush is not hitting the armature. A pile of worn off starter brush stuff laying in the starter can feed extra voltage back into the 12 volt sides of the system when you energize the starter.
ET
09-20-2010 09:23:06
What is the voltage at the starter? Check it acrossed the two battery cables, it should be 25 or 26 volts. What does it drop to when you hit the starter. Bad connections will get hot. You might take the cover right off the starter on the tractor and see if the brushes are used up and blow out any residue in there.
elevatorman 724
09-20-2010 08:09:44
sounds like a loose connection or bad ground coming from one of the batteries. either have to go down the line from each battery with a meter looking for voltage drop. or you can jump parts of the battery cables out with jumper cable to find bad connection. could be on feed side or ground side
