I ran across this little NAPA filter (#3943) and thought it looked like it might make a neat set-up to help keep my fuel cleaner. It needs a rubber grommet on the housing inlet to seal to the filter inlet and a small spring at the bottom to hold the filter tight to the grommet.
Posted this on the Farmall forum and I found out that it"s really dumb to try to keep fuel any cleaner than the original sediment bowl screen set-up. Another disadvantage that was pointed out was that the filter would have to be replaced - to expensive I guess.
It"s just an idea that looks good to me and I think the cleaner you can keep your fuel, the better. If no one agrees that"s fine and if someone wants to try the filter that"s fine too.
